8 years ago
PLL's in Cyclone V
I am trying to use the output of a PLL to drive a logic in FPGA. I'm not sure which clock should be connected as the 'refclk' for the PLL and how the 'outclk' of the PLL should clock my logic.
I have tried using a 50MHz clock (PIN AF_14) as a refclk for the PLL, and used the PLL 'outclk' as a clock input but my logic does produce any output. Could you please help?
Also, when I check my logic in ModelSim, the correct results are obtained.
Thank you.
    Apologies for the late reply. I did a lot of trial and error tests. I was able to achieve higher clock speeds. But I wanted to confirm if this is the right way. Here is the top level code:
    module top(
    input clk,
    input rst,
    input driver_clk,
    output pll_out,
    output locked_port,
    output data
    driver d1(
    .clk(driver_clk),
    .rst(rst),
    .data_out(data)
    pll pll_inst (
    .refclk (clk), // refclk.clk
    .rst (rst), // reset.reset
    .outclk_0 (pll_out), // outclk0.clk
    .locked (locked_port) // locked.export
    endmodule
    The pll_out port is connected to PIN_AH12 and I am using driver_clk is connected to PIN_AJ12 which is the the clock input for the driver module. The 'data' port is connected to HSMC pin 'PIN_B13' and I have also assigned the 'pll_outclk' as a GCLK.
    Is this the right way to go about? Because my output signal have a lot of jitters and distortions.
    Thanks for all your help.
