8 years agoPLL's in Cyclone V
Hello, I am trying to use the output of a PLL to drive a logic in FPGA. I'm not sure which clock should be connected as the 'refclk' for the PLL and how the 'outclk' of the PLL should clock my ...
8 years agoHello,
Apologies for the delay. I conducted a lot of trial and error tests. I am not sure if this is the way to go about. This is the top level code: module top( input clk, input rst, input driver_clk, output pll_out, output locked_port, output data ); driver d1( .clk(driver_clk), .rst(rst), .data_out(data) ); pll pll_inst ( .refclk (clk), // refclk.clk .rst (rst), // reset.reset .outclk_0 (pll_out), // outclk0.clk .locked (locked_port) // locked.export ); endmodule I am using PIN_AF14(clk) as the refclk for the PLL, I am assigning the output from the PLL (outclk) to PIN_AH12 and I am using the PIN_AJ12 as the input to the 'driver' module. The scope shows the increase in frequency. But there is lotta noise and jitter in the output signal from the HSMC PIN_B13. I have also made the outclk from the PLL as GCLK. Is this the right way to go about? Thanks for all your help.
