16 years agoPLL reconfiguration (stratix III)
Hello, I would like to make use of the S3's PLL reconfiguration feature. Ideally, this would entail a host CPU programming the settings for the scan chain in order to target some (reasonab...
16 years agoI understand. I actually tried to create such a thing at one point but ultimately determined it wasn't worth the time investment. In addition, some of the Altera megafunctions are actually java applications which I've been able to decompile and retrieve the algorithms that way. However, with the PLL, this is not the case. If you happen to come across some useful code, or happen to derive it, let us know.
Jake
