16 years agoPLL reconfiguration (stratix III)
Hello, I would like to make use of the S3's PLL reconfiguration feature. Ideally, this would entail a host CPU programming the settings for the scan chain in order to target some (reasonab...
16 years agoIs there a set of frequencies that you are planning on configuring the PLL to or is it essentially random? What I have done in the past is simply use the megawizard to get all the counter settings for each frequency configuration I was going to use, and record them.
Jake
