11 years agoPLL problem using LVDS RX and TX pins on the same bank in a Cyclone V
Hello all, I'm building a small loopback test setup, where I output data coming from a data pattern generated to a pair of LVDS signals (data & clock) and receive those same signals in another ...
11 years agoBy the way, you could use duplex mode ALTLVDS instead of two separate TX and RX only ALTLVDS. Both the TX and RX can still work independently.
