16 years agoPLL outputs to drive 50 ohm loads
I need two outputs from a single PLL of CYCLONE-III 3C16. Both the outputs are single-ended. One of outputs is 100MHz and the other is 120MHz-200MHz which will be dynamically configured through NIOS-...
16 years ago --- Quote Start --- However, it is not as good as parallel termination. --- Quote End --- In which regard? For LVTTL/LVCMOS outputs, parallel termination can't be used. Calibration resistors rup and rdn would be needed with calibrated termination only.
