16 years agoPLL outputs to drive 50 ohm loads
I need two outputs from a single PLL of CYCLONE-III 3C16. Both the outputs are single-ended. One of outputs is 100MHz and the other is 120MHz-200MHz which will be dynamically configured through NIOS-...
16 years agoThanks. I did consider using series termination. However, it is not as good as parallel termination. If Cyclone III series termination is used, 2 extra I/Os, rup and rdn will be used or 2 external resistors will be used.
