16 years agoPLL outputs to drive 50 ohm loads
I need two outputs from a single PLL of CYCLONE-III 3C16. Both the outputs are single-ended. One of outputs is 100MHz and the other is 120MHz-200MHz which will be dynamically configured through NIOS-...
16 years agoThe maximum ratings say -25/+40 mA, also internal series termination isn't supported for the 3.3 V node. It mainly depends on the required receive level which isn't nebtioned in your post.
