lambert_yu
Contributor
1 year agoPLL IP simulation under UVM simluation environment
Hi, quartus version : 19.1 IP : IOPLL & FPLL issue : Now, I integrated fpga into asic simulation environment which use uvm, I made sure I have input all fpga libraries and simulation model, and th...
- 1 year ago
Hi Lambert,
Generally speaking, our IP is not simulated using UVM. If the issue is solely due to the use of UVM, which causes different results, then I suspect that the issue may not be related to UVM’s handling of the reset/input clock, but rather that the library might not fully support UVM.
WZ
WZ2
1 year agoHi Lambert,
WZ
