PLL frequency doubling but shouldn't
- 5 years ago
Hi Joossss,
Thanks for your code!
I was able to reproduce the issue that you mentioned.
In the screen shot that you had shared, the output of the LVDS_CLK_inst (buffer) is not clean. There are some red lines ('X') on the buffer output. Same happened in my code as well (see signal /top_tb/dut/clk_in) . Result was that the PLL output was double the input clock.
Then in the test bench, instead of using the procedure clk_gen, I drove the differential clock inputs using simple process.
SIGNAL clk_in_p : STD_LOGIC := '1';
SIGNAL clk_in_n : STD_LOGIC := '0';
PROCESS
BEGIN
clk_in_p <= not clk_in_p;
clk_in_n <= not clk_in_n;
WAIT FOR 6.6666 ns;
END PROCESS;
With this the buffer output was clean and the PLL generated the output as expected. See the screen shot.
May be due to the 'procedure' there is an delta delay added to the input signals and they are not phase aligned to each other, so the buffer output is not clean.
That impacted the PLL output as well.
Regards.
Hi Joossss,
PROCESS
BEGIN
WAIT FOR 6.6666 ns;
END PROCESS;
Regards.
- Joossss5 years ago
Hey!
Thanks this works indeed, I only tried to use this process, because I tried to solve the same issue with it, by introducing delays into one of the lines, because before this I used
lvds_clk_p <= not lvds_clk_p after 3.3 ns; lvds_clk_n <= not lvds_clk_p; -- 150 MHzand this also didn't work.
Anyway, thanks for solving the issue.
