14 years ago
PLL dedicated input pin?
Hello.
In my design I want to use DDR2 external memory through ALTMEMPHY. The reference in external memory design guideline says I should trace the feeding clock to the dedicated pll input pin (avoiding global clk net), but how do I find this pin? There is nothing mentioned in pinout list about pll inputs. BTW, the chip is ep4cgx75cf23 if it may be necessary.
    I've found a table, but it seem to be connections between GCLK networks and PLL outputs... still nothing about inputs :( .
    I've just found another confusing thing about placing CK/CK# pins. It said:
    --- Quote Start ---
    Place any differential I/O pin pair (DIFFIO) in the same bank or on the same side as the data pins. You can use either side of the device for wraparound interfaces. The first CK/CK# pair cannot be placed in the same row or column pad group as any of the DQ pins
    --- Quote End ---
    What does it mean? CK/CK# should not be placed in the same bank as DQ? Or it should not occupy same row/column of pins? But according to pin-out list there is no possible configuration to place all DQs and have at least one "free" row/collumn in same I/O bank:
    http://s18.postimage.org/gwiu1tfbb/pin_assignment.png
    In the clocking resources chapter of the handbook, there should be a table which says which of the dedicated clock input pins can drive which PLLs.
