GuilhermeBarbosa
1 year agoPLL creation with IP Catalog (refclock less than 5MHz)
Hello, I'm a college graduate from Brazil at Federal Technological University of Paraná and I'm having problems setting up a PLL from IP catalog, would you please help me? I've been assigned to...
ShengN_altera
1 year agoHi,
No. The min legal refclk frequency is 5mhz.
Sheng
FvM
1 year agoHi,
besides frequency range problem, PLL can only synchronize to a continuous clock signal. Red encircled signal rather requires some kind of CDR circuit that reconstructs a continuous clock matching signal edges. Cyclone V has no hardware CDR features, soft CDR can be however implemented utilizing PLL dynamic phase shift.
Frank
P.S.: Not sure if you need to exactly synchronize to signal clock. If you just want to decode the (apparently Manchester encoded) data stream, an UART approach with sufficient oversampling ratio is probably the straightforward way.
