16 years agoPlease help with flash configuration
hello,
i try to send data to flash but it does not work (DE1 board). i did not use cfi or nios, just program the FPGA. the configuration is --oe we ce reset --H L L H the pin out is: FL_ADDR[0] PIN_AB20 FL_ADDR[1] PIN_AA14 FL_ADDR[2] PIN_Y16 FL_ADDR[3] PIN_R15 FL_ADDR[4] PIN_T15 FL_ADDR[5] PIN_U15 FL_ADDR[6] PIN_V15 FL_ADDR[7] PIN_W15 FL_ADDR[8] PIN_R14 FL_ADDR[9] PIN_Y13 FL_ADDR[10] PIN_R12 FL_ADDR[11] PIN_T12 FL_ADDR[12] PIN_AB14 FL_ADDR[13] PIN_AA13 FL_ADDR[14] PIN_AB13 FL_ADDR[15] PIN_AA12 FL_ADDR[16] PIN_AB12 FL_ADDR[17] PIN_AA20 FL_ADDR[18] PIN_U14 FL_ADDR[19] PIN_V14 FL_ADDR[20] PIN_U13 FL_ADDR[21] PIN_R13 FL_DQ[0] PIN_AB16 FL_DQ[1] PIN_AA16 FL_DQ[2] PIN_AB17 FL_DQ[3] PIN_AA17 FL_DQ[4] PIN_AB18 FL_DQ[5] PIN_AA18 FL_DQ[6] PIN_AB19 FL_DQ[7] PIN_AA19 FL_OE_N PIN_AA15 FL_RST_N PIN_W14 FL_WE_N PIN_Y14 reset PIN_L22 led PIN_R20 clk50 PIN_L1 Flash_CE_N PIN_AB15 Thanks.No RepliesBe the first to reply
