15 years agoPlease Help! Getting Compilation Error in Quartus
Hi I'm new to QuartusII and also VHDL, I'm trying to compile an IIR filter for a MAXII device (EPM1270F256C5), but I'm getting this error: "Error (10414): VHDL Unsupported Feature error at filt...
15 years agoYou can manually convert them
OR Write Matlab script to do that Either case, you need to determine how may bits you need to use for. But this is a topic for DSP. Once you setting down on number of bit in the system. You need to run simulation probably in Matlab to verify the filter response.
