14 years agoPLDT-2 Trainer
Greetings, I have the PLDT-2 trainer from RSR Electronics. It has the old style parallel cable. I have used it in the past with Quartus II without difficulty for schematic and design entry. We...
14 years agoI would check the bios on the system, and see if changing the parallel port mode makes a difference.
You can also try running in XP mode to see if it makes a difference or run an virtual machine.. Pete
