Place Stage Error(19724) on Arria 10 with Quartus Prime Pro 18.1
Hi Syafieq,
" set_global_assignment -name GLOBAL_PLACEMENT_EFFORT "OPTIMIZE FOR HIGH UTILIZATION" " didn't help to eliminate error I encountered but "set_instance_assignment -name CLOCK_REGION ..." worked perfectly well. Thanks a lot for your help.
Kind Regards,
Huseyin
Hi Huseyin, hi Syafieq,
Thanks to both of you for your kind responses.
Unfortunately, I confirm that" set_global_assignment -name GLOBAL_PLACEMENT_EFFORT "OPTIMIZE FOR HIGH UTILIZATION" " did not help.
Like Huseyin, I can say that my problem was not related with the device size, because the logic utilization was around 30%.
I temporarily addessed this issue by reducing the hardware footprint of my design, specifically targeting the fanout of the concerned clocks. That is why I have not exprerimented the second suggestion very quickly.
With the complete design, I finally managed to fit without errors by promoting the concerned clocks to large periphery clocks : "set_instance_assignment -name GLOBAL_SIGNAL LARGE_PERIPHERY_CLOCK -to <clock_signal_name>".
I suppose it has the same kind of impact as your suggestion of enlarging clock regions with the CLOCK_REGION assignment.
Roland
