Roland_T
6 years agoPlace Stage Error(19724) on Arria 10 with Quartus Prime Pro 18.1
I am currently experiencing a problem with an Arria 10 FPGA (10AS066K3F40E2SG) design that fails to fit with Quartus Prime Pro 18.1.
During the Place Stage, Quartus posts several info mess...
Huseyin
6 years agoI also have the same problem with Cyclone 10 GX. Problem is only solved when manual logic placement asignments are used (which are supplied with the DP RX-TX 4K Reference Design). The interesting part is manual logic placement works even if the region is not adjacent to transceiver block. Also problem is not related with the device size because the logic utilization is around %50. I am looking for a systematic approach for this issue.
