14 years agoPlace & Route (Noob Question)
Hi All, I am new to Altera devices and am wanting to know the function of the Quartus II fitter. Is the place and route fitter used to customize placement 'inside' the actual Altera device? Is ...
14 years agoplace and route is referring to the design inside the FPGA, you can't do the rest of your project with Quartus itself - though you will need to work closely with whoever is doing the board design on the I/O assignments of the FPGA
to do the board you need a schematic/layout package. there are high end tools like Mentor and Cadence or low end tools like Eagle and DipTrace. there should be no problem doing a Cyclone design in a low end tool, but Arria and Stratix designs would probably benefit from some of the features of high end tools - for example HyperLynx signal integrity simulation
