8 years ago
Pio write data error
Hi all,
I am using IOWR_ALTERA_AVALON_PIOS macros to write data onto pios. But when I am writing the data onto 1 pins, all the other pins are assigned the same value at the same time. Does anyone know why this happens? Thank you very much!
    --- Quote Start ---
    Maybe how data has interpreted is a problem.
    LSB bits are considered during reading & writing.
    1. What is the PIO width set?
    2. Can you share your code?
    Or
    Try with below code.
    Example1: For single bit controle consider below code and try
    IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, count & 0x01);
    while(delay < 2000000)
    delay++;
    count++;
    Example2: 2-PIO of 3bits of width, for switches and leads.
      int in;
      while (1)
          in = IORD_ALTERA_AVALON_PIO_DATA(SW_PIO_BASE) & 0x07;//we are consedering/requried least 3bits from switch
                  if(in==0)//if all swith are zero
                   IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0);
                  else if(in==1)
                       IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 1);
    Anand Raj Shankar
    --- Quote End ---
    The DB Width I am setting is 8 bits. It is for driving LCD. I have fixed previous problem. But now, I have a new problem. When I am trying to write DB. I got nothing on this 8-bits width signal out onto oscilloscope. The code is attached.
    # include "stdio.h"# include "stdint.h"# include "unistd.h"# include "system.h"# include "linker.h"# include "lcd_driver.h"
    //#include "Character.h"# include "altera_avalon_pio_regs.h"
    //#include "lcd_driver.h"
    int main()
    while(1){
    IOWR_ALTERA_AVALON_PIO_DATA(LCD_DB_BASE, 0x01);
    usleep(50000);
    IOWR_ALTERA_AVALON_PIO_DATA(LCD_DB_BASE, 0x00);
    usleep(50000);
    return 0;
    In this code, DB[0] should be toggled, right? which is not. My setting for this pio peripheral is 8-bit width as output. Could you help me with that? Thank you very much!
    Or
    delay++;
    count++;
      int in;
      while (1)
                  else if(in==1)
    Anand Raj Shankar
