12 years agoPin Planner LVDS Differential Pair Selection
I am fighting Pin Planner at every turn. In my QSF file, I have the following: set_location_assignment PIN_T22 -to "HSMC_RX_D_N(n)"
set_instance_assignment -name IO_STANDARD LVDS -to "HSMC_RX_D...
12 years ago --- Quote Start --- Thank you so much for the files. I will be sure to put them to good use! --- Quote End --- Ask questions if you wonder why I did something the way I did. My scripts should be fairly obvious once you compare them to the Altera generated script, i.e., mine are more concise and readable :) --- Quote Start --- I was trying to use import / export from the assignments tab and was annoyed that it wasn't working. --- Quote End --- Tcl scripting is the way to go to control Quartus and Modelsim. Cheers. Dave
