15 years agoPin Damaged question
hello, we are using altera Cyclone1 EP1C6.. we use the IC in an I/O application.. the I/O pins of the IC are connected to external device and user can touch these pins by touching the end ...
15 years agoI get this IC from NXP PESDXS4UD its description is
( Quadruple ElectroStatic Discharge (ESD) protection diode arrays in a SOT457 (SC-74) small Surface-Mounted Device (SMD) plastic package designed to protect up to 4 signal lines from the damage caused by ESD and other transients. ) will it work without the zener diode?
