15 years agoPin Damaged question
hello, we are using altera Cyclone1 EP1C6.. we use the IC in an I/O application.. the I/O pins of the IC are connected to external device and user can touch these pins by touching the end ...
15 years agothanks alot..
I read the datasheet of the IC of NXP but there is a question about the PIN number 5 VP (supply voltage), I do not understand can it be 3.3V?? I can not send the link because my post count must be 5 or greater but it is at nxp.com/documents/data_sheet/IP4220CZ6.pdf
