15 years agopin compatibility of FPGA with same number of pins
hello, i am currently using EP3C16F484 in my project, and now i want to upgrade to EP3C40F484, need i design again the schematics and relayout the PCB? or i can directly use a EP3C40F484 to solder...
15 years ago --- Quote Start --- Select the device you want migrate to in Quartus device settings. Then go to pin planner and select "Pin migration view" in the view menu. Here you will see the pinout of the fpga devices and you can highlight the differences. Good luck! --- Quote End --- yeh, it works, thanks a lot.
