15 years agopin compatibility of FPGA with same number of pins
hello, i am currently using EP3C16F484 in my project, and now i want to upgrade to EP3C40F484, need i design again the schematics and relayout the PCB? or i can directly use a EP3C40F484 to solder...
15 years ago --- Quote Start --- You can use the EP3C40 in place of EP3C16 if migration compatibiltiy has been beared in mind during pin placement. See the migration devices setting in Quartus assignments. --- Quote End --- thanks for your replying. so you mean that the funtion of some pins between these two devices is incompatible, if i used one of these pins in 3C16, it could not be replaced by 3C40 without redesigning.
