9 years agoPin Assignments won't import
Hello, I'm using Cyclone II chip, on Quartus II 12.1 SP1. This is required because my school uses that version. Anyhow, when I try to go to assignments > import assignments..I try to import by...
9 years agoOpen the .csv file (easiest to view in Excel but any text editor should do). Check that the column headers match the names of the columns in Pin Planner. You could also simply copy and paste the assignments into Pin Planner or Assignment Editor (depending on how the file is formatted).
