9 years ago
pin assignment problem
I am new to quartus ii. I have created a bdf file instead of verilog/vhdl . i am taking input through terasic data conversion card and through sma cable i am giving a sine wave but i am not able to see the input through signal tap analyzer . when i see the pin planner there is no location , bank and pin assigned to inputs and outputs . i have imported the pin assignments. what can i do so the output and input will be assigned.
Help will be highly appreciated.
Thanks in Advance
    --- Quote Start ---
    There will be at least an automatically selected fitter location shown for each port signal after compilation if you didn't assign a location. Did you select a FPGA type in device assignments?
    How?
    --- Quote End ---
    Yeah there is automatic selected fitter but the i cant find the correct input in signal tap. i have attached a screenshot of pin planner.
    --- Quote Start ---
    Hi shipra7993,
    I have never heard importing pin assignments method in Quartus II/Prime software. As far I have done which is known to be working is either, assigning the pin manually one-by-one or copy and paste a list of the pins into the Pin Assignment. I would recommend that you cross check the schematics for the correct pins to be assign in the Pin Assignment especially the clock pins which is a must in order to run the Signal Tap.
    nyusof
    --- Quote End ---
    Hi Nyusof,
    Thanks!
    I have attached the screenshot of the import assignments, that is what i did for pin assignments but i am not getting the desired input and when i manually assign pin it doesn't accepts.
    Shipra
    --- Quote Start ---
    Thanks in Advance
    --- Quote End ---
    Hi shipra7993,
    nyusof
    --- Quote Start ---
    --- Quote End ---
    --- Quote Start ---
    I have imported the pin assignments
    --- Quote End ---
    How?
