9 years agopin assignment problem
Hi, I am new to quartus ii. I have created a bdf file instead of verilog/vhdl . i am taking input through terasic data conversion card and through sma cable i am giving a sine wave but i am not...
9 years ago --- Quote Start --- Hi shipra7993, I have never heard importing pin assignments method in Quartus II/Prime software. As far I have done which is known to be working is either, assigning the pin manually one-by-one or copy and paste a list of the pins into the Pin Assignment. I would recommend that you cross check the schematics for the correct pins to be assign in the Pin Assignment especially the clock pins which is a must in order to run the Signal Tap. Regards, nyusof (This message was posted on behalf of Intel Corporation) --- Quote End --- Hi Nyusof, Thanks! I have attached the screenshot of the import assignments, that is what i did for pin assignments but i am not getting the desired input and when i manually assign pin it doesn't accepts. Regards, Shipra
