17 years agoPin Assignment for Custom Component in SOPC
I am working on DE3 board with Stratic III device on it. I have successfully written a piece of verilog code which deserializes the LVDS data coming from HSTC port (an external ADC ic connected to HS...
17 years agoYou don't usually make pin assignments in SoPC builder. When you create your custom components and simply export the signals using a conduit interface. Then this ports become visible in the port list for the SoPC system. You can then connect them outside your SoPC system however you'd like.
Jake
