VYoung
3 years agoPhased Clock
Are there any Intel SoC FPGAs that provide a clock manager with different phased clock outputs? e.g. One 100 MHz input with four 200 MHz phased outputs (0 degree, 90 degrees, 180 degrees, and 270 deg...
tehjingy_Altera
3 years agoHi Vyoung
Yes. In the the IP configuration the you could select the numbers of clocks output you would like and the phase difference in between the clocks.
Please refer to the diagram below:
As for the fabric resource I do not have that information but I assume that it would not take up a lot of resource as it is a common IP that is being used.
Jingyang, Teh
