17 years ago
Phase Shift Reconfiguration
I am wanting to configure a phase shift routine on the Stratix II FPGA.
Within Quartus I have used the altpll_reconfig and altpll megafunctions to generate the apporopiate block diagrams. I have also created two mif files to be used - one the initial settings and one containing the reconfig settings.
However, from here I do not know how to modify the reconfig mif file to generate the appropiate phase shift - 45deg on clock 0.
Any help would be great,
    I have now managed to configue the phase shift - with the help of this example : http://www.altera.com.cn/literature/an/an367_3.zip
    However, my problem now is that each phase shift is off such a small magnitude. I have tried to change the extent of the shift, but cannot seem to. Does anyone know how to do this?
    Thanks for any help!
    --- Quote Start ---
    When you open the altpll with megawizard, you can change the phase in "output clocks" tab and generate mif in "PLL reconfiguration" tab. Put mif file name and push "Generate A Configuration File" button. After generating mif file, you cancel the altpll to save original setting.
    --- Quote End ---
    I have tried this. However when i generate mif files for different phase shift configurations (which i have changed via the ALT_PLL megafunction),there is no difference between the mif files.
