17 years agoPhase Shift Reconfiguration
Hi, I am wanting to configure a phase shift routine on the Stratix II FPGA. Within Quartus I have used the altpll_reconfig and altpll megafunctions to generate the apporopiate block diag...
17 years ago --- Quote Start --- When you open the altpll with megawizard, you can change the phase in "output clocks" tab and generate mif in "PLL reconfiguration" tab. Put mif file name and push "Generate A Configuration File" button. After generating mif file, you cancel the altpll to save original setting. --- Quote End --- Hi, I have tried this. However when i generate mif files for different phase shift configurations (which i have changed via the ALT_PLL megafunction),there is no difference between the mif files.
