17 years agoPhase Shift Reconfiguration
Hi, I am wanting to configure a phase shift routine on the Stratix II FPGA. Within Quartus I have used the altpll_reconfig and altpll megafunctions to generate the apporopiate block diag...
17 years agoWhen you open the altpll with megawizard, you can change the phase in "output clocks" tab and generate mif in "PLL reconfiguration" tab. Put mif file name and push "Generate A Configuration File" button. After generating mif file, you cancel the altpll to save original setting.
