11 years agoPhase Relationship after PLL reconfiguration in CycloneIV
Hi, I am using EP4CE55 FPGA in my project. i have problem with PLL usage. I have enabled reconfiguration and dynamic phase shift of PLL. i want to know after i reconfigure PLL to output a d...
11 years agoThanks for your reply.
the doc you point to is about 28-nm devices, not CycloneIV, i think cycloneIV is very different to CycloneV device. and you mean when resetting PLL(hold areset high for some time), the phase relationship will revert back to the setting which i initially set in megawizard? according to the signals grasped by oscilloscope, this is not the case. i set the original phase relationship to 0 degree, however, when i reconfigure PLL to a different frequency(in this process, i hold areset high, then released), then check the phase relationship, i found there is a phase shift between two clocks, and this puzzles me much. further more, when i reconfigure to another frequency, the phase shift also changes! another point i want to clear is that i directly register in the 144-bit chain to reconfigure the PLL to change the output frequency, the output frequency is correct everytime which i checked with oscilloscope. is there any document discuss this issue? or did i miss something? thanks, ingdxdy
