16 years agophase between 2 PLL's in different FPGA
Hello, I have a system with 2 FPGA's. In each FPGA I need a clock of 40MHz. I can generate it with a PLL in each board. My question is: If the 2 PLL's generate the 40MHz signal from...
16 years agoYou can't have a fixed phase shift between a source 24MHz clock and a generated 40MHz clock.
If you generated 48MHz instead, then it would be feasible.
