Matt1
8 years agoPFL Mega Function: Setup time Issue
hi all, I am trying to implement Altera PFL IP (configuration is done for FPPx16) in MAX5 CPLD. As per the datasheet i did all the constraining for the respective signals. From the CPLD design com...
GuaBin_N_Intel
Contributor
8 years agoThis is resource limitation in your device part number. If you can't choose a larger max device, I think the option you have is to reduce the running core speed.
Matt1
7 years agohi GNg,
I solved the timing issues which were reported by the Quartus by changing the seed value and Fitter settings in the tool.
now the tool reports Fmax as 100.2Mhz
Thanks for your support
