Matt1
8 years agoPFL Mega Function: Setup time Issue
hi all, I am trying to implement Altera PFL IP (configuration is done for FPPx16) in MAX5 CPLD. As per the datasheet i did all the constraining for the respective signals. From the CPLD design com...
GuaBin_N_Intel
Contributor
8 years agoHave you tried to set IP GUI>Flash Programming>Speed? Also, set the fitter>optimization mode(performance) but it may have little help.
No, there is no UG stated Fmax of PFL IP in any device. It is soft IP and we have varies product range and families. What you can do is to run a compile with standalone PFL and see the Fmax you get.
