Performing user access to the configuration serial flash device
Hi Eugeny,
Glad that you could make some progress.
To your earlier question,
>It can be used as user I/O after configuration.
Do I understand it properly - if I use AS configuration mode, the ASDO pin will only be an output in user mode? Or can I configure it do be bi-directional?
ASDO pin can be used as a normal I/O once configuration is over. During config in AS mode, it is by default an output only.
Let us know if the case can be closed. You may reopen it in case you still face the issue.
Regards.
It worked in general, but I still have intermittent problems. Working at 37.6 MHz, some builds do not read data bits properly. Not completely (so that I can recognize data by the eye), but some bits are invalid. I have tried Quartus options for the pins:
Please help me.
- EugenyB5 years ago
I have solved the problem. The W25Q128 is properly working at 56 MHz, even with additional load attached (scope / download cable).
Thank you for your support.
