rshal2
6 years agoPeloader hang in clock calibration
Hello, The following function get hang in my application. I can't knows exactly why, because preloader is getting compiled with debug information (Is there a way to Turn it off)? What I see is: ...
FawazJ_Altera
6 years agoHello Sir,
May I know how did you build your preloader? is it through bsp-editor?
Furthermore, which device is that?
Thank you
rshal2
6 years agoHi,
I suspect that it is issues of osc1 reference clock.
In our case it is 50Mhz, and csel is 0.
Maybe the actual accuracy of our clock is not sufficient ? I haven't find the precision requirement for osc1 in reference.
I also see that it terrasic DE-10 they use 25Mhz as input with csel=0, maybe 50Mhz is too much near the limitation of csel=0 (10 to 50Mhz) ?
