rshal2
6 years agoPeloader hang in clock calibration
Hello, The following function get hang in my application. I can't knows exactly why, because preloader is getting compiled with debug information (Is there a way to Turn it off)? What I see is: ...
FawazJ_Altera
6 years agoHello Sir,
May I know how did you build your preloader? is it through bsp-editor?
Furthermore, which device is that?
Thank you
rshal2
6 years agoHello,
These are the next steps I've tried:
- change csel from 0x10 to 0x0. Now it behaves slightly different. I manage to pass the previous problematic code line, but in just the next line of code it get hangs:
/* clear safe mode */
DEBUG_MEMORY
cm_write_ctrl(
readl(SOCFPGA_CLKMGR_ADDRESS + CLKMGR_CTRL_ADDRESS) |
CLKMGR_CTRL_SAFEMODE_SET(CLKMGR_CTRL_SAFEMODE_MASK));Why should it hang here ?
2. I than tried to skip "cm_basic_init" routine.
Now I manage to continue till the end of preloader before jumping to u-boot.
What does it mean ? Why cm_basic_init fails to configure pll ?
3. I've also noticed the following patch:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd06202014_496.html
Should this patch be applied with quartus 15.1 ?
Note: I try to debug preloader using debugger. Is this the reason for the pll calibration issue ?
