Peloader hang in clock calibration
Hello Sir,
May I know how did you build your preloader? is it through bsp-editor?
Furthermore, which device is that?
Thank you
We are using bsp-editor, with device ASXFB5 (arria V) with quartus 15.1.
I suspect that it is related to clock input clock1 ? but since debugging behaves a little tricky (I tried to remove some parts, but it behaves in-consistently), therefore I think it would be better if I build with no optimization.
Yet, It always hang cm_basic_init() routine.
I verified the following:
osc1 and osc2 are 50M with scope.
bootinfo register is 0x2b5 (bsel=0x5, csel=0x2).
What can be the reason for preloader hang in cm_basic_init?
- rshal26 years ago
In further debugging it seems it get hangs right here:
/* Take all three PLLs out of bypass when safe mode is cleared. */ DEBUG_MEMORY cm_write_bypass( CLKMGR_BYPASS_PERPLLSRC_SET( CLKMGR_BYPASS_PERPLLSRC_ENUM_SELECT_EOSC1) | CLKMGR_BYPASS_SDRPLLSRC_SET( CLKMGR_BYPASS_SDRPLLSRC_ENUM_SELECT_EOSC1) | CLKMGR_BYPASS_PERPLL_SET(CLKMGR_BYPASS_ENUM_DISABLE) | CLKMGR_BYPASS_SDRPLL_SET(CLKMGR_BYPASS_ENUM_DISABLE) | CLKMGR_BYPASS_MAINPLL_SET(CLKMGR_BYPASS_ENUM_DISABLE));for some reason, I can't put a breakpoint in this line but if I remove the above line from code, then I get into next line and continue debugging.
Any idea what it means ?
Thanks!
