Peloader hang in clock calibration
Hello Sir,
May I know how did you build your preloader? is it through bsp-editor?
Furthermore, which device is that?
Thank you
- rshal26 years ago
I suspect that it is issues of osc1 reference clock.
In our case it is 50Mhz, and csel is 0.
Maybe the actual accuracy of our clock is not sufficient ? I haven't find the precision requirement for osc1 in reference.
I also see that it terrasic DE-10 they use 25Mhz as input with csel=0, maybe 50Mhz is too much near the limitation of csel=0 (10 to 50Mhz) ?
- rshal26 years ago
These are the next steps I've tried:
- change csel from 0x10 to 0x0. Now it behaves slightly different. I manage to pass the previous problematic code line, but in just the next line of code it get hangs:
/* clear safe mode */ DEBUG_MEMORY cm_write_ctrl( readl(SOCFPGA_CLKMGR_ADDRESS + CLKMGR_CTRL_ADDRESS) | CLKMGR_CTRL_SAFEMODE_SET(CLKMGR_CTRL_SAFEMODE_MASK));Why should it hang here ?
2. I than tried to skip "cm_basic_init" routine.
Now I manage to continue till the end of preloader before jumping to u-boot.
What does it mean ? Why cm_basic_init fails to configure pll ?
3. I've also noticed the following patch:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd06202014_496.html
Should this patch be applied with quartus 15.1 ?
Note: I try to debug preloader using debugger. Is this the reason for the pll calibration issue ?
- rshal26 years ago
We are using bsp-editor, with device ASXFB5 (arria V) with quartus 15.1.
I suspect that it is related to clock input clock1 ? but since debugging behaves a little tricky (I tried to remove some parts, but it behaves in-consistently), therefore I think it would be better if I build with no optimization.
Yet, It always hang cm_basic_init() routine.
I verified the following:
osc1 and osc2 are 50M with scope.
bootinfo register is 0x2b5 (bsel=0x5, csel=0x2).
What can be the reason for preloader hang in cm_basic_init?
- rshal26 years ago
In further debugging it seems it get hangs right here:
/* Take all three PLLs out of bypass when safe mode is cleared. */ DEBUG_MEMORY cm_write_bypass( CLKMGR_BYPASS_PERPLLSRC_SET( CLKMGR_BYPASS_PERPLLSRC_ENUM_SELECT_EOSC1) | CLKMGR_BYPASS_SDRPLLSRC_SET( CLKMGR_BYPASS_SDRPLLSRC_ENUM_SELECT_EOSC1) | CLKMGR_BYPASS_PERPLL_SET(CLKMGR_BYPASS_ENUM_DISABLE) | CLKMGR_BYPASS_SDRPLL_SET(CLKMGR_BYPASS_ENUM_DISABLE) | CLKMGR_BYPASS_MAINPLL_SET(CLKMGR_BYPASS_ENUM_DISABLE));for some reason, I can't put a breakpoint in this line but if I remove the above line from code, then I get into next line and continue debugging.
Any idea what it means ?
Thanks!
