14 years agoPDN design
Hello there,
I'm working on a Arria V design but I'm a little confused about power supply and PDN requirements. If I look in the Arria V datasheet, recommended operation conditions for VCC are set to 1.07-1.1-1.13V (min-typ-max). This equates to 3% allowable variation in the VCC voltage. At first glance I would think that I must design so that the voltage is always within this range which means that AC ripple + distribution drop + PSU tolerance must be less than 3%. However; in the PDN tool, recommended ripple is set to 5% for VCC with an Arria V device. Furthermore this includes only the AC ripple as the value is used directly to calculate the de-cap network. So; the question is: should the values given under recommended operating conditions only be seen as "DC" requirements setting the level for PSU tolerance and distribution drop. Or should I view recommended operating conditions as "AC" requirements and design so that these values are meet for all frequencies up to F- effective? If the first is true, shouldn't the datasheet provide a recommendation for AC ripple? If not, why does the PDN tool recommend much higher values? Hope somebody can clarify :-)1 Reply
hello kasperovergaard (http://www.alteraforum.com/forum/member.php?u=65856),
I'm glad you asked this question as I was just wondering about the same issue. I have seen in the Arria® II Device Family Pin Connection Guidelines that some supplies require a 5mV max ripple, but there is no spec anywhere to be seen in the Arria V. Have you found any further information on this? Thanks. (http://www.alteraforum.com/forum/member.php?u=65856)
