14 years agoPDN design
Hello there, I'm working on a Arria V design but I'm a little confused about power supply and PDN requirements. If I look in the Arria V datasheet, recommended operation conditions for VC...
14 years agohello kasperovergaard (http://www.alteraforum.com/forum/member.php?u=65856),
I'm glad you asked this question as I was just wondering about the same issue. I have seen in the Arria® II Device Family Pin Connection Guidelines that some supplies require a 5mV max ripple, but there is no spec anywhere to be seen in the Arria V. Have you found any further information on this? Thanks. (http://www.alteraforum.com/forum/member.php?u=65856)
