16 years agoPCS mandatory for Inter Transceiver Block synchronisation ?
My current design consists in interfacing a high-speed ADC (18-bit@2Gbps) to the Stx IV-GX receiver blocks. The main concern is ADC<->FPGA transceivers synchronisation. How to make sure all the...
16 years agoAC coupled, which could also limit the minimum transition density depending on how big the capacitor is. But I think the CDR would probably be the limiting factor.
If it can't handle (say) 32 bits in a row with no transitions, I guess that would mean its sampling phase may be off until the transitions start coming again. Then the first few bits may be sampled incorrectly before the CDR is able to lock again.
