PCS Direct on serial loopback
As I understand it, you have inquiries related to the rx_data_valid for the S10 XCVR. To ensure we are on the same page, just woud like to check with you on the following:
1. What is the specific XCVR PHY that you are using? Is it L/H-Tile Native PHY?
2. What is the specific Quartus version that you are using? Just wonder if you have had a chance to try with different Quartus version to help isolating Quartus version dependent problem?
3. Just wonder if you have had a chance to perform a functional simulation ie in Modelsim to check on the behavior?
4. Before the serial loopback is asserted, what is the lock status of the CDR?
5. If you are using external loopback (no serial loopback used), ie plug and unplug cable, is there any difference in the observation?
