9 years agoPCIE Pinout doubts and Problems Cyclone V
Hi guys, Well I have to communicate two FPGA cyclone V by PCIe, but I dont know if I can use all pins. Here are some doubts about pins - PRSNT#1 :This pin if a hot plugg detec, but...
9 years agoYour question is too wide, it is basically need to know you want to use it as active or passive, then serial or parallel, then is it multi device? End up like combination of active serial active serial multi device or fast passive parallel, or etc.
For most combination, nstatus, nconfig, conf_done are to pull up resistor; nCE can be ground or pull down. You can even tie 2 pins together such that they enter user mode together, no delay or leading at timing diagram. It really depend on the configuration you want. Best Regards, Tzi Khang, Lim (This message was posted on behalf of Intel Corporation)
