PCIe Endpoint to PCIe EndPoint communication
Hi Sir,
Yes any EP device can initiate transaction to other EP through a bridge.
But what I am confusing here is you mentioned the FPGA EP will act as a bridge. I don't think we can use the FPGA as a bridge.
So, in your application, you will still need a physical bridge that connecting the 2 EP.
- Matt17 years ago
BCT_Intel..thanks for the reply.
its just a misunderstanding about the bridge that i mentioned in my query.sorry for that.
In some intel fpga i found 2 Hard PCie IP.
my question , is it possible to connect these 2 IPs which are configured as ENDPoint, So that one PCie EP receive the data from a RP and other EP will transfer data to another RP.
Do u have some reference designs for this..
you mentioned about bridge is the cutom design(eg: dual port Ram) which need to be interfaced with these 2 Endpoints .Correct me if I am wrong?
