9 years agoPCIe Communication not working
Hi all, We used a cyclone IV FPGA in one of our design. Due to some assembly error ,a wrong FPGA was mounted on to the board. Later we identified the issue and removed the FPGA and mounted the cor...
9 years agoHi,
Some general thoughts and questions: 1. Is this was tested before and approved to be working setup or new untested prototype? 2. Have you checked that FPGA board is not damaged due to wrong FPGA and board rework? (There are no short circuits, no damaged power supply IC ect.?). 3. Does FPGA boots to user mode, can it be reprogrammed? 4. Have you checked that PC motherboard is not damaged by installing other working PCIe board?
