16 years agoPCI interrupts
Hi All, We have used SOPC builder to add a conventional PCI component to our SOPC system. The system makes use of the Intan interrupt pin. My question is how do you actually generate a PCI...
8 years agoHi Guys,
Anyone is successful in using Mailbox registers to generate interrupts to the Host? Iam using Arria10 FPGA and the application interface as "Avalon-MM with DMA", does this support mailbox registers? Request to please share on how to write into these a2p_mailbox and p2a_mailbox registers and how to enable the interrupts? Hi vernmid, Please share how does the CRA port helped to fix this issue? Thanks. Regards linus_alt
