15 years agoPCI interface with FPGA
Please if anyone can guide me how to input the data in FPGA through PCI interface
i will be obliged if u tell the steps to follow regards uzmeed15 Replies
Hi uzmeed,
http://www.gage-applied.com/products/digitizer_pci/14_bit/octopus_83xx.htm To me, this looks like a 'black box' oscilloscope card, that you can only access via proprietary windows drivers and libraries. I do not see any options to customize this board. Where did you see details about creating a custom FPGA configuration that you could then send data over the PCI interface? Cheers, Dave - Altera_Forum
Hi
Dave thanx again yes here is the link to the datasheet as im unable to post a link so u please go to website of gage-applied.com and then follow the link Products/PDF/Octopus_CS82XX.pdf this data sheet is that of 82xx but i will be using 83xx (some how unable to open it ) i wil be using 8 channel 100MHz sampling rate with 14 bit digitization i hope u can help me more in this regard thanx uzmeed - Altera_Forum
If you have a digitizer board, then do you have a link to its data sheet?
Does the board have an FPGA or a PCI chip for the PCI interface? Provide details. How fast does your digitizer operate? How fast does your PCI interface operate? Eg., 33MHz clock/32-bit, or 66MHz clock/64-bit, or what? The PCI bus can perform up to say 40MB/s pretty easily using a Master interface, eg. your board DMAing to host memory (a PC). Cheers, Dave - Altera_Forum
thnak u dave
u ans atleast set the direction for me let me explain more i hav a digitizer board that output data on PCI interface the work i have to do is that i hav to pick the data from PCI at the rate it is sampled regards uzmeed - Altera_Forum
Please provide more details, eg., do you have a board with an FPGA already on it, if so, what FPGA?
There are two types of PCI devices; masters and targets. Targets are pretty simple and dumb. They can respond to reads and writes on the PCI bus, and their performance is pretty slow. However, if all you need to do is blink an LED, then a PCI target might work for you. I recall seeing a PCI Lite core mentioned in the Embedded IP and Peripherals guide. http://www.altera.com/literature/ug/ug_embedded_ip.pdf If you need high performance over the PCI bus, then you need a PCI master interface. A PCI master interface can become the 'master' of the PCI bus, and it initiates PCI reads and writes. The master interface normally contains a DMA controller to perform read and write transactions. If you are designing a board, then you need to determine the cost of the PCI master/target core (or the cost of writing one) relative to the use of something like a PLX Technologies PCI Master/Target interface chip, eg. the PCI9054 (or some of the newer devices). The device drivers for PCI interfaces are pretty simple. I can point you to code examples for Linux if you need them. Cheers, Dave
